Question about 3rd gen weight.
Old Oct 26, 2003 | 06:51 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Wondering what an 86 IROC T-Top car would weight in stock form. Im trying to get mine down to under 3000#s without the driver in it.
As of now, all interior is gone, and one of Summits plastic race seats are going in. The only thing left inside the car right now is the center console and the dash. No Carpet, no seats etc..
Everything except the engine, and the radiator, are gone out of the engine bay. No emmisions no a/c crap. Everything from inside the dash, the heater core, and everything is gone.
What would you think roughly my car would weigh in current form, and can you think of anything else I could pull out?
Old Oct 26, 2003 | 08:03 PM
Dave89IROC's Avatar
my 89 is around 3660# with me in it(250#)
Old Oct 26, 2003 | 08:33 PM
Garage Inc.'s Avatar
couldn't get the '86 Darth..found out that the '87 Iroc 5.0 5 speed is 3250, then +30 for t tops, so 3280lbs.
here man, add these as you go along
Item lbs add/subtract
Power Seat 7.9
AM9 Fold Down Rear Seat -3.5
AU3 Power Locks 3.1
A31 Power Windows 3.9
B84 Side Molding 1.3
CC1 T-Tops 29.5
C49 Rear defogger 0.9
C60 Air conditioning 41.7 with V-6
C60 Air Conditioning 42.6 with 305 TPI & 700R4
C60 Air conditioning 46.3 with 305 TBI & 700R4
C60 Air Conditioning 42.7 with L98
DE1 Back window Shade 18.5
D34 Vanity Mirror 0.4
DG7 Electric Side Mirrors 1.3
F41 Suspension -6.6
J65 4-wheel disc brakes 2.6 (Z/28 w/L98 only)
K34 Cruise control 5.3
MD8 Automatic Trans 101.9 (with 305 & 350)
N10 Dual exhaust 12.8
T96 Fog Lamps 4.4
UA1 H.D. Battery 0.4
UL5 Radio delete -5.7
U75 Power Antenna 2.6
Old Oct 26, 2003 | 08:39 PM
Camarocracy's Avatar
If you want some good weight reduciton, ditch that heavy rear hatch glass for a rear notchback decklid. Can also get a fiberglass hood, and lightweight wheels. An aluminum radiator, aluminum water pump from edlebrock. There is a big post over on thirdgen.org about people switching the stock metal tank for a plastic 4thgen tank. Can switch to a manual tranny. Can remove your ground effets. Goto a single exhaust outlet instead of dual tips.
Now, if you want serious weight reduction [not recommended for the street], you can go with a full fiberglass body.
Old Oct 26, 2003 | 08:41 PM
DarthIROC's Avatar
I know that damned power window motor weight more than 3.9 lbs
Old Oct 26, 2003 | 09:23 PM
DarthIROC's Avatar
And I think I am going with fiberglass fenders cause I found some for like $130 per. And definetley a fiberglass hood cause i need more clerance. Tranny is getting switched. either to a powerglide or a TH-400. I would gain a bit with the 400 I think.
This interests me, what do you mean by notchback decklid? Like a convertable one?
Old Oct 27, 2003 | 04:34 AM
kevin 2.8's Avatar
(not to steal your thunder)
notchback decklid came on some trans ams
it sort of makes the back look like the rear of a ferrari testarossa (my fav), lotus esprit, toyota mr2, with the rear pillars sweeping out and holding in a smaller looking rear window. sort of like the fiero rear glass/rear roof. it should make the car a bit lighter due to the small glass
good luck finding one tho
wish i had some louvers
Old Oct 27, 2003 | 04:41 AM
kevin 2.8's Avatar
can you swap lexan t-tops with glass ones? are the lexan ones lighter..? just a thought
Old Oct 27, 2003 | 05:48 AM
Dave89IROC's Avatar
yes, lexan are about half the weight of glass
Old Oct 27, 2003 | 09:44 AM
Here is the Hawk's Thirdgen Parts notchback that you can buy, It sorta looks like the Fiero deck.
http://www.hawksthirdgenparts.com/in...il?v=1&pid=463
Old Oct 27, 2003 | 11:36 AM
Jaysz28's Avatar
If the car is not going to be driven on the street, you can remove the front and rear inner bumper/crash protection supports. You know, that honeycomb material under the front and rear bumper covers.
Disclaimer: This will remove most of the crash absorbing material from your car. Do not do this if the car will see any street use. I do not take any responsibility if you decide to remove them on your own accord and die from an accident.
Old Oct 27, 2003 | 06:10 PM
Zepher's Avatar
I think the fiberglass fenders weigh more than the stock ones.
Stock fenders don't really weigh anything.
Old Oct 28, 2003 | 07:51 PM
Ucantcme57's Avatar
I have a Fiberglass hood and fiberglass fenders, Getting soon a tubular k-member, and aluminum heads.. That should be worth some major weight.. Go to Thirdgen.org and there is a weight table or something in the faq's or something..
Old Oct 28, 2003 | 11:23 PM
12Second3rdgen's Avatar
My car weighs 3025 pounds without driver with cast iron heads, steel fenders and no lexan.
Ditch the heater casing on the firewall, ditch the power steering, ditch the back seat, ditch the carpet, fiberglass cowl hood, aluminum radiator, aluminum 15" Weld wheels and you can get to the point I am at .
Seth
Old Mar 10, 2004 | 03:59 PM
GreaseMonkey83's Avatar
you could cut alot of metal out of the front and rear bumpers, i took out just enough so that the plastic shells stayed in their original position, and a fiberglass lift off hood will alow you to remove the hood latch and its supporting brackets. Aluminum heads and block if you have deep pockets.
