what is the CFM on a stock 90 model TB?
Old Nov 3, 2003 | 09:03 PM
LALT1's Avatar
I have read on here that alot of peopel recomend the holley 670 CFM TB just curious as to what the stocker was for a 90 305 TB car. my car now has a basically frsh rebuilt 350 with the LT1 cam in it but seems to fall off pretty bad above like 3800.
Old Nov 3, 2003 | 11:24 PM
Garage Inc.'s Avatar
500
Old Nov 4, 2003 | 08:50 PM
Dave89IROC's Avatar
I've heard that if the rating is converted to the same scale as carbs, it is around 370-400 cfm, the one from a 454 is near the holley's 670 (same 2" bores)
Old Nov 4, 2003 | 08:56 PM
LALT1's Avatar
Thx for the info guys, now to use the holley or the 454 TB what intake has to be used?
Old Nov 4, 2003 | 09:00 PM
Dave89IROC's Avatar
you need an aftermarket TBI intake that has 2" openings, or a carb intake and an adapter w/2" openings
you may also be able to open up the holes in a stock intake, but it will still be restricted in the rest of the intake
Old Nov 4, 2003 | 09:01 PM
Dave89IROC's Avatar
you will also need the wiring connectors of a truck, since both the holley unit(designed for the truck) and the 454 one have different connectors on the sensors
Old Nov 5, 2003 | 07:27 AM
305RSlc's Avatar
400cfm is stock with the 1 11/16" bores
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
