slp injectors??
Old Nov 1, 2003 | 10:42 AM
cals400ex's Avatar
slp injectors??
i noticed that slp had some 25 ft/lb GM/bosch injectors for $100. i wasn't sure if it was worth it or not. right now the iroc 350 is running 14.2's and i plan on putting a stealth ram or mini ram on it and also a cam. i didn't know if i would need bigger injectors than the 25's for these mods or not? any help would be great. thanks
Old Nov 1, 2003 | 11:16 AM
aklim's Avatar
They seem ok but not sure about their quality. You might be able to use them but that is what I think. In any case, I would talk to the person burning the EPROM and see what they want. You will have to redo your EPROM to make it all work together for best results. Who is doing your EPROM?
Old Nov 3, 2003 | 09:04 AM
cals400ex's Avatar
right now the car has pcmforless programming. i wasn't sure if they were good quality or not either.
Old Nov 3, 2003 | 10:58 AM
Zepher's Avatar
I went with the Ford racing SVO injectors since a lot of people I know went with them., but for $100, I'd give those ones a try.
Old Nov 3, 2003 | 11:43 AM
aklim's Avatar
If they don't do reburns till it gets right on, they are not good quality. NO ONE I have every heard of is that good to get it nuts on in 1 shot. When I did intakes and headers, Lingenfelter took several hours to get it done. They had to take readings, burn and reburn till it was on the money.
HarleyZ28
Oct 5, 2015 06:23 AM
QuickSilver02
Apr 7, 2015 11:12 AM
