balance a 383?
Old Oct 10, 2003 | 08:11 PM
Chris`s85Z28's Avatar
balance a 383?
I have a 383 kit in my 350 block no flywheel or balancer the guy who did it said it was balanced at scat but don`t balanced kits come with a balancer and flywheel
do I have to take the kit out and balance it now the guy that built it said no. but theres no warranty on the engine I have $3000 in it, balancing is another $800 I sure hope not.
Will the engine last if I run a good aftermarket balancer?
Old Oct 10, 2003 | 10:09 PM
StealthElephant's Avatar
What do you want to balance? The crankshaft should have a weight set on it, your rods/pistons should match the weight. If it's all new you shouldn't have a problem. A good damper is always a good thing, I think that 383 is externally balanced by the damper.
Old Oct 11, 2003 | 12:33 AM
aklim's Avatar
Mine was externally balanced.
Jeff1904
Jun 5, 2016 05:00 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
