Ram Air TPI
Old Oct 29, 2003 | 10:42 PM
Rage's Avatar
Ram Air TPI
Alright. Im in the process of installing ram air on my car and just have a few questions. MUST the fog lights be removed in order for this to work? Cause I like the fog lights, and would rather not. If they dont have to be remved tell me how I can work around em.
Old Oct 29, 2003 | 10:44 PM
doug791's Avatar
just catch air from right behind em, think you have to do a little it of cutting stuff but nothing major.
Old Oct 30, 2003 | 01:40 AM
dj haf's Avatar
i left my fog lights on... but im taking them off soon - they dont work and i think my ram air setup would benifit a little if i took them off.... i dont think it'll give me a SOTP difference (lol i doubt it'll make any difference honestly), but... it wouldnt hurt to try huh?
Old Oct 30, 2003 | 01:47 PM
Rage's Avatar
Ok, but when you install the Ram Air, your no longer cooling your radiator with air are you?
Old Oct 30, 2003 | 02:09 PM
doug791's Avatar
look under your car.....see that huge plastic piece that hangs down under the nose....that is solely there to scoop air into the rad....i dont worry about the cooling air lost from the fog lights...
Old Oct 31, 2003 | 07:13 PM
lordmetalz28's Avatar
i put that ram air on my car in the summer and the hottest 90 degree day we had i didnt over heat a lick i didnt even rise above 180 but of course i do have a 200 degree fan switch just in case
Old Nov 2, 2003 | 12:34 AM
Rage's Avatar
I did the Ram Air, and I also hooked up my fans to where both of them run constantly. When I bought the car, neither of the fans worked, I rigged one, and yesterday I rigged the other. So, it runs really cold now. I ran a very sad 15.1x at 88mph, BUT the humidity was awful and we had a head wind, so, Im definately looking at some 14's next week.(If the weather works out). My best run is a 14.9 and that was at 84k miles soo(now at 102k), even w/ the extra mileage, Im hoping to get a lil better than that, hopefully 14.5's w/ some Nitto T555R's and timing adjustments. . I just noticed that it is set at 6 stock, and that's awful, so, Im going to bump that to 10, and if it still aint right, i'll try 12. Thanx guys.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
