"Early Style 202 Heads"
Old Nov 2, 2003 | 06:58 PM
Black6SpdTA's Avatar
What are they? Are they any good? The seller of the L98 I'm looking at told me it had them. It's out of an '88. Thanks
-Rippin
Old Nov 2, 2003 | 07:40 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Depends on how early they are. pre 68 heads only had one acessory hole, so you cant bolt all of your stuff up to them. They flow Pretty well with some mild porting. Probbaly better than L98s, and they have the bigger valves. The earlier ones also had smaller combustion chambers too. As they were mostly on 327s. So that makes a big difference too. Why dont you go over to the place and pull a valvecover so you can check the numbers on the head. That should give you the info you need.
Old Nov 2, 2003 | 08:11 PM
They've got to be Post-1968 then because the motor is in the car and running. Did 2.02 heads ever come stock in 3rd gens? I thought stock heads were 1.94? Thanks Darth.
-Rippin
Old Nov 2, 2003 | 08:19 PM
DarthIROC's Avatar
-Rippin
No they didnt. They are 1.94/1.50s I think. I believe the vette L98 heads got 2.00 valves. maybe the iron L98s did too.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 15, 2015 11:53 AM
Pwilson59
Sep 3, 2015 08:47 PM
