Coolant Temp Sensor Location
Old Oct 27, 2003 | 11:39 PM
Kuruption562's Avatar
Exclamation Coolant Temp Sensor Location
A LiL Help On Locating it Please.
Old Oct 28, 2003 | 12:27 AM
Scratch This, I Done Found it,.
Old Oct 28, 2003 | 12:56 AM
What tools are needed to take this out and replace it? Do i need to disconnect my alternator or something because there is very little space to work.
Old Oct 28, 2003 | 01:15 AM
aklim's Avatar
Can you get to it with a deep socket?
Old Oct 28, 2003 | 01:30 AM
No dont think so, The black plastic peice is wider than the screw itself...
Old Oct 28, 2003 | 06:49 AM
doug791's Avatar
pretty sure i got mine off with a socket? Ill look at it tonight and see if anything comes to mind.
Old Oct 28, 2003 | 11:03 AM
aklim's Avatar
Could you take off the TB and try get it with a wrench?
Old Oct 28, 2003 | 02:34 PM
doug791's Avatar
are you sure youre talking about the coolant temp sensor? Mine is right below the tb on the passenger side and is sticking right out of the block and just has the black clip for the wiring sticking on it. Pull the clip off, and put a wrench on it....couldnt be much more simple. You either have to have your sensor in a different location? (did it change from year to year?) or youre talking about a different sensor.
Old Oct 28, 2003 | 02:47 PM
doug791's Avatar
here is the coolant temp sensor. As you can see the clip pops off and a wrench can be slipped on and it just screws out. sorry for it being a little small i dont have the patience to try to mess with it.
Old Oct 28, 2003 | 04:01 PM
StealthElephant's Avatar
Thank you Doug!
A picture..finally...I tried hooking it up to the temp sens on the passenger side of the block under the exhaust manifold with no luck....so I just gotta go to my ol 305 and take that sens off and hook my temp wire up. Thnx
Old Oct 28, 2003 | 06:28 PM
There are too many things in the way to get to it with the socket. Yes mine is in front like yourrs but a little more to the right. The thing that holds the alternator is in the way...
Old Oct 28, 2003 | 09:09 PM
doug791's Avatar
cant even get it with a wrench? Time to invest in a stubby ratchet set maybe?
warmeck
Apr 27, 2015 04:34 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
