code 33 and 36
code 33 and 36
i took my car into shop class friday and ran the Snap On Scan tool on my car and got a code:
33-MAF sensor or circut too high
36-Airflow sensor burnoff failure
this means i need a new MAF sensor doesnt it? im not lookin forward to that,arent they expensie??
It doesn't necessarily mean you need a new sensor. The code 36 is for the relay, not the sensor. Those are about $10 and take 5 minutes to change.
The code 33 could mean a bunch of things. It could be something simple like a TPS adjustment or it's possible that it could be the sensor too.
i meant code 33,sorry.
o and another thing to throw out,i was tryin to set my idle speed earlier (i grounded the ALDL conn.,dissconnected the IAC,turned key on for 30 seconds,and started car up) and unscrewed it to try to get it down to 400 RPM's and all it went down to was 1,100,WTF.
you might have a vacumn leak, that will cause high idle, and can set a MAF code
Make sure the key was on for 30sec.."before"...you unplugged the IAC, that'll fully seat the pintle.
And 400rpm is WAY low, 750 is the norm.
Also check the fuse for the MAF, near the fender-well, two wires going to a dead end plug, inside is the fuse. This happened to me on my '86 2.8MPI and I swapped my MAF with a buddy's and still coded. Then I traced all of the wiring for the MAF and found the fuse was blown...
iroczone.com says to set it at 400 w/ the IAC unplugged and w/ it plugged in it should idle at 600 or so. i just grounded A&B,unhooked the IAC and turned the key on for 30 secs. then started it,maybe thats y, ill try it tmw. not trying to pick ur brain or anything,but do u happen to remember which fender-well? im guessing passenger but a better direction is always better and thanx alot for all the help.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
Jul 8, 2002 01:37 AM
