Just took out the smog pump... have a question
Old Oct 28, 2003 | 04:28 PM
dj haf's Avatar
alright... i just finished taking out the smog pump, but what do i do with all those hoses? here's a pic i took of the passenger side of the engine bay... can anyone tell me what to do with the rest of the smog stuff here in the pic? thanks guys
Old Oct 28, 2003 | 08:53 PM
Chuck!'s Avatar
If I remember right you just need to take them off your AIR tubes off your manifolds then plug those.
Old Oct 28, 2003 | 09:35 PM
aklim's Avatar
You take the pump off and at the back it leads to a AIR diverter box. You take that box off too and tie the wires up safely. It should have hoses to both the AIR tubes in the manifolds. There is a check valve in between the AIR holes and the hoses. Take that off and cap it off. Also, one more hose goes to the cat with a check valve in between. Cap that off too
Old Oct 28, 2003 | 10:11 PM
dj haf's Avatar
check valve? what does it look like so i can figure out what it is, lol
Old Oct 29, 2003 | 01:02 AM
aklim's Avatar
There are 3 on your car. They are what the AIR hose plugs onto. The are black and can be screwed off. On your manifolds, you have 4 little tubes going into it. These 4 tubes join up to one large tube. This tube has a black thing onto which your AIR hose is connected.
Old Oct 29, 2003 | 01:05 AM
dj haf's Avatar
ahh i know what you're talking about... thats what i figured but i didnt want to assume wrong. ill get everything off first thing in the morning thanks aklim
Old Oct 29, 2003 | 08:52 PM
shwine617's Avatar
I did it the easy and performance adding way, get a set of hooker super comp headers. This way you get more performance, better sound. And this way you don't have to plug anything off. And maybe in the future u want to get headers anyway. I also removed my smog pump, my question is where do you put the wires from it? I just zip tied them off to the side. Is this OK?
thanks
Old Oct 29, 2003 | 09:12 PM
aklim's Avatar
I would have got the smog legal headers. I did that just in case they start doing a visual inspection and I could run to the JY and get it and have in on in half an hour to an hour.
BTW, zip tie them so they don't get chewed up by the belts.
Old Oct 29, 2003 | 09:29 PM
shwine617's Avatar
Yea I would have but I got the car with the headers on it and the smog pump hoses were just dangling there, so I had no use for it. thanks aklim, yea i tied them away from the belt, I tied them onto the injector wireing harness
cheapchevy
Apr 8, 2015 08:48 PM
edman
Mar 13, 2015 09:39 PM
alphaauto
Jan 23, 2015 07:42 AM
markaubuchon
Jan 14, 2015 01:48 AM
deadmanrunning
Jan 3, 2015 01:12 PM
