3RD gen with LT1 want Supercharger
i have a 87 Z28 and i put a LT1 in it and it runs great but i have spray on my IROC and now i want a supercharger!!
does anyone know or has done a LT1 swap and then put a supercharger on it?
any info would help greatly
From: Teeter-tottering between Brilliance and Insanity
I wouldnt think it would be any differnt from supercharging any LT1. I would just check the forced induction forum, there should be tons of guys in there with sc'ed Lt1s.
Originally posted by Geezer powered
Well to warn you lt1's and supercharger's have had a bad relationship. No more then 4.5-6psi for boost. Remeber the lt1 has a high compression ratio. Not forced friendly
thanks i already asked in forced induction and no body can help me
as for my motor i have a hotcam motor on a set of worked stock castings
i was already thinking of pulling it out and swapping my all forged 355 shortblock in there BTW my dad just disassembled his motor for a 396 and i am taking the top half of the motor
and i dont think that i will have a problem of running boost on a set of 8.5:1 pistons
I've seen plenty of people run 8-11PSI on stock LT1 bottom ends through ProCharger intercooled kits and have the engine last for a decent amout of time
Frezza ran his ProCharger kit for 3 years with no problems.
Darth, Now you know us car "folk" can't just "swap in" dished pistons. We'd end up doing a stroker, serious heads/cam, etc. Boost on a stock bottom end rules. it's why we do it. it's cheaper than pulling an engine for a full rebuild.
Frezza ran his ProCharger kit for 3 years with no problems.Darth, Now you know us car "folk" can't just "swap in" dished pistons. We'd end up doing a stroker, serious heads/cam, etc. Boost on a stock bottom end rules. it's why we do it. it's cheaper than pulling an engine for a full rebuild.
To hell with being conservative
Im gonna go till I exhaust my resources. Then I start cutting corners.
I have first hand experience with attempting to install a supercharger on a LT1 in a 3rd Gen.
I had an ATI P600B for a 4th Gen LT1 car that I attempted to install in my car. It will NOT work. The head unit bolts onto the engine where the 3rd Gen steering box/frame rail is.
I sold the blower kit to someone on the board here (slimdawson), who also has a 3rd Gen LT1. I told him it won't fit, but he's STILL working on it, like 1.5 years later.
Maybe if you have custom brackets fabricated to install the blower in a different location (the top of the engine) it may work, but even then it's not going to be easy.
Sucks...it's a real PITA.
Eric
Eric
CARiD
Jan 27, 2015 06:27 AM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
