Signs Of Fuel Pump Goin Out?
Old Oct 12, 2003 | 02:44 PM
Kuruption562's Avatar
let me know. my **** been turning off when im off the gas.
Old Oct 12, 2003 | 04:56 PM
Garage Inc.'s Avatar
check for leaks
Old Oct 12, 2003 | 05:08 PM
nah no leaks at all. Is there anything else that can cause my car to be at low RPMs and even turn off att times with alot of smoke when it starts on low rpms?
but sometimes it just starts good and idles good. any ideaas? i just had my fuel injectors cleaned yesterday, i feel alot better performance but it still turns off at red lights.
Old Oct 12, 2003 | 07:03 PM
aklim's Avatar
Check the fuel pressure. You may have to go with a gage taped onto your glass if you want to run for a while.
Old Oct 12, 2003 | 07:10 PM
Old Oct 13, 2003 | 09:04 AM
aklim's Avatar
A pump on the way out might show signs by not pressurizing the system when the key is in the on position. Also, the pressure might be low or sometimes cut out. If the car cuts out, and you have pressure, that is not the problem.
Old Oct 13, 2003 | 09:56 AM
chamorro's Avatar
i just replaced my pump a few weeks ago. check the fuel filter. if its dry, try replacing the fuel pump.
Old Oct 13, 2003 | 12:51 PM
Zepher's Avatar
bad fuel pump can idle normal but when you try to get on it with a load, the car will start to stumble. that is what my old 96 V6 Camaro would do.
Old Oct 13, 2003 | 05:54 PM
I replaced my fuel filter on saturday, it would let out the gas black as ****. And yeah i feel it stumble at times, like ill step on the gas and it feels like no power and it just stumbles.
Old Oct 13, 2003 | 11:58 PM
90rocz's Avatar
Have you tried "dry-Gas", wate in the tank can cause similar problems as a bad pump.
A pressure gage will help. Although, water will pumpo at a lower pressure, so it can be deciveing...
My wife's car had 2 QUARTS of water in the tank under the pump...symptoms was stumbling on acceleration, fine if not under load...stumble at sharp turns or hard stops. Or on steep inclines....the key was the "sloshing" would cause symptoms.
Old Oct 14, 2003 | 10:34 PM
aklim's Avatar
Dare I ask how this happened?
Old Oct 14, 2003 | 10:55 PM
FishPig's Avatar
You also might check your air filter, and your O2 sensor. I have know cars that this happened to them. IF it wasn't your pump or your filter and your getting the pressure that you need, maybe it is just needing a breath of air??? just a suggestion.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
