Name That Problem
Old Oct 21, 2003 | 07:54 PM
Kuruption562's Avatar
Unhappy Name That Problem
Aiight as i said in another post my car runs good when its cold, but after it warms up it runs like shiet. It starts to idle low and throws out smoke from the tail pipes when it gets hot after like 20-30 min of driving. Some times i need to keep my foot on the gas or it will turn off. Call It.
Old Oct 21, 2003 | 08:31 PM
Rice Killer87's Avatar
what color smoke is it?
Old Oct 21, 2003 | 08:50 PM
I beleive its black or just dark
Old Oct 22, 2003 | 04:46 PM
kevin 2.8's Avatar
you replace all your regular maintenence things?
Old Oct 22, 2003 | 05:33 PM
I changed oil, transmission fluid, filters, spark plugs about 1,000 miles ago. i just did the o2 sensor.
It Just throws out smog. Like when i take off fast like from my house i come back and see that my car has thrown thick smog on my cuzins front end. i pick it with my finger and its all black, also my tail pipes are black from the inside. do i need to replace my full exuast in cluding cat and all? The last owner had it installed this past jan, but i guess its a cheap brand or i dont know, but i love how it sounds. Need help!
Old Oct 22, 2003 | 05:49 PM
IROC-T's Avatar
For some reason you are running way to rich,don't think you'll need to change exhaust. However it could be restricted,look to see if you have any bends or crushed pipes anywhere. Your cat could be pluged-up,have a friend rev the motor and watch to see if the cat swells up alot,this will give you and idea if the cat is pluged.
Old Oct 22, 2003 | 06:15 PM
kevin 2.8's Avatar
check your timing and cut off your cat to see if its clear
Old Oct 22, 2003 | 09:29 PM
Damn how do i check my timings? do i take it to a shop?
Old Oct 23, 2003 | 12:38 AM
aklim's Avatar
If you don't have a timing light, you take it to a shop. No way you can fudge it.
Old Oct 23, 2003 | 12:58 PM
kevin 2.8's Avatar
after you get your timing adjusted, regardless of if it was the problem cut off the cat, the unburned fuel probalbly cooked it, and just consider yourself lucky it didnt warp your headers like mine causing power loss and unwanted bad noise.
Old Oct 23, 2003 | 01:27 PM
shwine617's Avatar
how many miles are on the motor?
are you sure ur not burning oil??
Old Oct 23, 2003 | 06:01 PM
It says 49,000 on it and the last owner told me it was on a rebuilt engine. so i believe i got 149,000 damn thats a lot
Old Oct 23, 2003 | 06:04 PM
shwine617's Avatar
does the oil level drop after a while? sound like a case of worn rings..so you get alot of blow by when you step on it.
Old Oct 27, 2003 | 01:43 AM
My Oil Gage Is Broken, So Its always down. :-(
Old Oct 27, 2003 | 08:33 AM
shwine617's Avatar
no I mean your dipstick, do you have to add oil once in a while? because your probably burinig it.
