small block into 1994 Camero
Old Oct 16, 2005 | 10:18 AM
Shorty's Avatar
I would like to but a small block into a 1994 Camero and would like ANY information about the necessity to change the suspension, or if it would even hold the small block without reinforcement. If there is a website or anyone willing to talk me thru this, I would be most appreciative. Thanks!
Old Oct 16, 2005 | 10:32 AM
v8pwrdz28's Avatar
Re: small block into 1994 Camero
first of all its "camaro" not "camero", im shocked u found the site and didnt go to cameroz28.com...
Old Oct 16, 2005 | 10:52 AM
1970z28's Avatar
it can be done, i put the lt1 in my 94 v-6 this past winter. you need to swapped out the k-member, i left the v-6 suspension in the car and had no problems. but if you are going to install a early model 350/400 in you may have to come up with the engine mounting brackets, from the k-member to the block. not sure but ithink moroso has a set o frame mounts and block mounts that will work.
Old Oct 16, 2005 | 01:29 PM
6SpdLT1Z's Avatar
I've also considererd doing this. My dad has a 350 SBC block for me to use, and I'd prolly buy a S10 beater to drive... Then after I was done I'd put the 3.4 into the S10.
What about clearance issues up top? distributor?
rojo10956
Classic Engine Tech
Dec 13, 2021 12:17 PM
dpw21562
Apr 16, 2015 09:41 AM
ad356
Apr 11, 2015 08:49 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
