1992 3.1L overheating need help.
Old May 8, 2005 | 03:57 PM
red96z's Avatar
1992 camaro 3.1L overheating need help.
I have a 92 with the 3.1L. It's been overheating a long time but i now have to drive the car everyday so i'm trying to fix it. i thought it was the cooling fan since the fan did not come on so i ran a toggle switch and that did not fix the problem. Then when the car was running hot i felt the upper hose and it had alot of pressure on it so i thought it was the thermostat so, i changed that out and now the problem seems worse. When i get out of the car the upper hose had a little pressure on it not like before but, there was a little. Also when i shut it off there are bubbles it the overflow tank. Is there a air bubble in the system or has the water bump gone bad?
Kinglouui
May 26, 2016 11:05 AM
David Dempsey
Mar 12, 2016 12:42 AM
surreybrad
Sep 29, 2015 09:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
