walbro PSI fall off
Old Aug 11, 2005 | 06:24 PM
viper03af's Avatar
walbro PSI fall off
i need few fast/correct anwser's
i installed the walbro and when i prime it the fuel psi falls from 45 to like 12 really fast......... is that normal ?
i have the corrigated hose and such and it has 2 clamps on the top and the pump was one tight so i only used one clamp
when motor is running or under boost the fuel PSI stays vary steady? 46 at idle
this is a v6 but same should apply
Old Aug 11, 2005 | 07:03 PM
viperkiller's Avatar
Re: walbro PSI fall off
wht do you mean by prime? if you open the shrader valve it will drop.
KYWes
Jun 14, 2022 06:52 AM
13qtr
Oct 28, 2016 08:11 PM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
