No Compression???
Old Jun 19, 2005 | 02:15 AM
MarcR94v6's Avatar
No Compression???
My neighbor and I just replaced gaskets on most of my engine and put everything back together and it won't start. When trying, it has a constant semi-high pitch sound. And sometimes it backfires in the front and smoke comes up. It also sounds like something rattling in there. And right before or during the rattling there is a beep from the car I've never heard before. My neighbor says that it keeps turning over like there's no compression.
Any ideas? I can give more detail later if needed.
Old Jun 19, 2005 | 12:33 PM
MarcR94v6's Avatar
Re: No Compression???
The book says to turn it 1 and a half turns, but there's no compression because the valves aren't closing. And they all need to be right so they don't clank. What do I do? I'm at TDC in # 1 position, which I was not at before, which was one problem. But there is still the question of compression.
Old Jun 19, 2005 | 01:46 PM
crasher88's Avatar
well first off lets start by what gaskets you replaced what all did you take off the car to replace those gaskets and try and eliminate possibilites one by one.
Old Jun 19, 2005 | 04:32 PM
MarcR94v6's Avatar
Problem solved. The Chilton/Haynes manual is WRONG. 1 and a half turns leaves no compression. We had a compression tester and learned what to do from there. Now we put it all back, and it runs good. Except oil is still leaking, which is why we did all of this to begin with. But he thinks it's because not enough sealer was put on that intake gasket. We're gonna take it apart and put it back together for the THIRD time later today. Hopefully we can fix that gasket and be done with it.
Old Jun 19, 2005 | 04:33 PM
MarcR94v6's Avatar
But thanks for the help, anyways crasher. False alarm.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
