95 3.4l V6 Raditor Flush how to ?
Old Jul 27, 2005 | 03:14 PM
Spllouder's Avatar
i want to change my raditor fluid in my other 1995 camaro v6 3.4l , but i cant find the bleeder screws so , i dont want to do it , unless i can find the bleeders screws so i can get all the air out of the system ? . where are they , and does anyone have a guide for flushing the raditor online ?
Also , how much total coolant does this setup hold when i refill it up ?
Thank you
Old Jul 30, 2005 | 09:20 PM
sivstaang's Avatar
Re: 95 3.4l V6 Raditor Flush how to ?
The usual bleeding process on a car for coolant systems, is to leave the rad. cap off and let the car run for about 15-20 mins and it will "burp". It will over flow a couple times then the t-stat will open up and suck the coolant in then yous low refill it and top it off THEN close the cap and then turn the car off or you will get a huge mess if you turn the car off with out putting the cap on first
Naanz
V6 Tech
Feb 14, 2016 11:11 AM
FredM
Jun 5, 2015 05:45 AM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
kksi
Feb 17, 2015 10:41 PM
SSR
V6 Tech
Aug 18, 2002 11:55 AM
