Dont know what to do with this car
Heres the deal
It's 98 with only 46K miles, It's a great car and I really like it! perfect blend of practical yet sporty I've owned it since 02 and bought it used with 10,000 miles.
I'm a maintance freek, If I cant do it I pay someone to do it right, I dont skip at all, Lately I've noticed that when starting up It sometimes blows a puff of blue smoke out the pipes, (burning oil) I only use mobile 1 and change it 3-4,000 miles, I dont drive hard, rarely floor it for any reason,
Also, now that it's getting more humid, my misfire problem is coming back I had the plugs+ wires changed 2 TIMES last summer! I dont want a repeat!
I looked under and last time I checked I pulled a wiere off a header, is their anything I can buy and wrap around my existing wires to help them last some longer? it pops sometimes especially on humid days so I just sence that its only going to get worse
In short I really want to put off spending 25K on a new car for a wile longer if possible, I know these arent major issues but the misfire is driving me crazy every hot day, what should I do?
I cant change the wires myself since thats beyond my level of work so what should I ask my mechanic to do?
Re: Dont know what to do with this car
put anti heat thingys around your wires / plugs .. i forgot the name .. its some sort of metal that this dude i know has on his 69' Camaro SS that he races at the track .. he hasnt had to change plugs / wires in a long time..
heat sheathing...
I put some on my car, when I did my plugs and wires... I have had no problems but only like 1.5 years, 17k miles. Especially after seeing one of my stock wires on the exhaust manifold
I got a 6ft. roll of 1000* sheething form summit for like $30, 1 foot per cylinder and Msd wires.
browse through "the great misfire mystery" thread at the top explains it.
And the puff of blue smoke...thatd be oil getting past your rings. Not to cheap and since the plugs are beyond you the rebuild should be done by a mechanic. Look on the bright side, you can build it stronger...
Today was a bit cooler so car ran just great!
Eric, I was actually going to try to IM you but your rarely on and ask you how your 3.8 does in FL with all the hot weather, thanks for replying
I had to go to the auto parts store today so I talked to one of the guys I normally deal with and he sugested that if they go we order a set of 8mm wires and get heat sheathing.
I'm going to try to stop by this speed shop by my work and see if I can get some kind of sheathing that goes over the existing wires to prolong their life if possible.
It's just so DANG hard to work under there! Cant even reach #2 I'd love to meet the engioneer who did this and kick him in the nuts
Thing is that works for me... if you had plugs and wires like my car? I'd say hit it up yourself, but I have tubualr manifolds and 98s don't and I hear they are alot harder to work.
PREPARE and MAY you bring bandages... MANY MANY bandages!!!
The smoke at startup is usually oil leaking past the valve seals, not the rings. It is common in older cars, although yours isn't that old. Either way, if it stops smoking theres nothing to worry about. If it keeps smoking or puffs when you stomp on it, then I would suspect rings.
Originally Posted by Need4Camaro
By all means H-E-DOUBLE-L-YES MUCH harder!
then I saw a car with lincoln log manifolds and realized the differnce
Wow, I never knew the Headers were THAT different, anyone have pictures? it's 2000 + right? anyone thing their is horse power gains? where they just more rounder?
I got under there the other day and re-ajusted the looms and black plastic things the wieres are in so it's pretty good right now, I might buy more of that black plastic stuff to protect an area where I think it needs it.
I stoped by that speed shop but they didnt have anything that I could fabricate to an existing setup, I guess I'll just wate till they really crap out and then get it re-done correctly.
BTW, I'm going to have a HARD time getting my mechanic to do this job again, he bitched alot about the last time!
~Chris
~Chris
1996LT1Z28
Middle Atlantic
12-04-2014 09:37 PM
1996LT1Z28
12-04-2014 09:20 PM
