fuel filter
Old Jun 20, 2005 | 07:17 PM
Jonas's Avatar
fuel filter
i was wondering what all do i need to do to change the fuel filter on my 94 3.4L v6 camaro ...let me know...thanks guys!
Old Jun 20, 2005 | 07:25 PM
Need4Camaro's Avatar
Re: fuel filter
Well first rules first...
...No smoking!
Have a nice day sir!
Old Jun 20, 2005 | 08:05 PM
Re: fuel filter
In my 3.8 it was under the car on the driverside rear right past the rear driverside wheel.
You'll need a 10MM wrench if it's the same...
Fuel Line puller
Fuel filter
and some nice clothes you don't mind getting gassy...Goggles help too because fuel doesn't suite well with the eyes...
Old Jun 20, 2005 | 09:19 PM
ianwells100's Avatar
Re: fuel filter
yeah, its really easy, just unplug the fuel door latch, thing... y'know what i mean, undo some bolts, unclip it, put in new one, should take 10 mins tops...
Old Jun 20, 2005 | 09:23 PM
Hedzilla's Avatar
Re: fuel filter
Heres what you do:
Jack the car up, preferabily level.
Pull the fuel pump fuse and start the car, let it run till it dies.
Unbolt the hard fuel line from the front of the filter using a wrench. Some gas will spill out.
If need be, slide the whole filter out of the metal band, and kink the plastic line to keep gas from coming out.
Take a flathead screwdriver and undo the white clips in the rear and pull the plastic line out.
Put the new filter on.
Reinstall the fuse.
Taa daa. You did it.
Old Jun 21, 2005 | 12:26 AM
ImportKILLER's Avatar
Re: fuel filter
Wear some protective glasses cuz the girl is going to give you an automotive golden shower.
Old Jun 21, 2005 | 10:25 AM
deadmeat2004's Avatar
Re: fuel filter
its really easy, just do what was said and its a easy 10 min job.
Old Jun 21, 2005 | 12:29 PM
Jonas's Avatar
Re: fuel filter
alright thanks for the help everyone!
Old Jun 30, 2005 | 07:47 PM
1993CaMaRoZ28ofIdAhO's Avatar
Re: fuel filter
sweet
CaptainObviousI
29
Apr 29, 2021 10:35 PM
PCLZ28
Dec 24, 2015 05:19 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
30thZ4C
Dec 26, 2014 05:09 PM
