rpm cuts off at 4000!
having problem with 1997 Chevy camaro V-6 3.8.was working fine yesterday when i got home,this morning i turned it on and noticed it was a little shaky,so i changed the fuel filter checked the plugs everything seems fine. when i rev the engine up it cuts off,it wont turn off it just doesnt rev any higher than 4000 rpm`s.i .has anyone had this kind of trouble before,any advise is greatly appreciated .thanks.
Re: rpm cuts off at 4000!
lol thats normal when you are standing still(ive played with it before)
get it on the road... once going like 20mph+ itll rev all the way up... no idea why it does that, but i know its normal...
cory
cory
no codes,and its not normal .it was running great the night before,now it kinda stutters,it runs real ruff.what p/n rev limiter,is this a sensor .will it make run real crappy,thanks for the help.
the cutt off at 4000 RPM in nutrale is normal
the car runing bad is not does it stutter going down the raod ?
Just went through this on my 2000 3.8
FOLLOW THESE STEPS:
Check all the wires, make sure they arent cracked, if you haven't changed your wires or plugs in 50,000 miles change them all.
I had to change an ignition coil and all the wires and plugs, still stumbled around and cut off at 4000rpm
I then changed the fuel filter and it fixed the stumble, still cut off at 4000
It ended up being a bad cat, see if the exhaust smells funny or if you hear a rattling coming from under the passenger side, also if your exhaust feels colder and the engine warmer than normal thats a sign too.
Got the cat replaced today (literally) and I have no more stumbles, codes or cut off at 4000rpm
John
FOLLOW THESE STEPS:
John
in our cars, rough running like you describe is usually due to bad plug wires. get a decent set of 7.5mm or 8mm wires and prepare to cut your knuckles. wires are a damn b1tch to swap.
hope that helps.
oh, and if you find any metal shrouds or shields on the plug caps when you remove the old wires, be sure to put them on the new wires when you install. or you might have to go through this mess in another year or so.
hope that helps.
I don't know if you fixed your problem yet knowing that you posted this a while ago. I was having the same symptoms as you. I brought my car to a mechanic to get a diagnosis. Came back and they said my cat was literally falling apart inside therefore clogging it up. I was able to have my cat replaced for free by a local chevy dealer because the mechanic i brought it to said that chevy has or had some kind of warranty for the cat itself if your car has less than 70,000miles on it. I called up the dealership just to confirm, and the mechanic was right. So I saved around $500-$700. Got my car back a couple days later, whoa was I happy!!!
May 1, 2015 01:14 PM
