Weird Voltage Surge problem....Help
Old Jul 2, 2005 | 12:54 AM
JaxCamaroGuy's Avatar
Ok, sometimes but not always, When im slowing down i put the car in neutral (5spd manual) and hit my brakes, the lights dim and my volts drop and then they`ll come back up. Sound like an alternator maybe to you guys?
Old Jul 2, 2005 | 08:34 PM
deadmeat2004's Avatar
Re: Weird Voltage Surge problem....Help
just your car using the juice. Dont worry. Unless its really really bad.
Old Jul 2, 2005 | 09:38 PM
ianwells100's Avatar
exactly, most of the times this happens when i'm breaking, or even going into gear and dont give it enough revs....
just incase, check/clean teh battery terminals, and if you're **** about it, check out to make sure all your grounds are good and clean, but this shouldn't be necessary
Old Jul 9, 2005 | 04:21 PM
99andMine's Avatar
Mine does the same thing. Brand new red top Optima and a new alternator later Ive learned that unless you want to drop 200 on a higher watt amp, the problem will always exist. Luckily I needed these parts or I would have just lived with the problem and never known. Makes having a system a PITA also...
Nayr
Mar 3, 2023 08:34 PM
truecontr3
Oct 11, 2015 09:30 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
Aug 7, 2015 01:26 PM
