Egr
Old Jun 6, 2005 | 06:38 PM
JB_96RS's Avatar
Egr
I have the service engine soon light on and I was told from the mechanic that the code is for the EGR system. Is this most likely the EGR valve? Where is the valve located and if I replace it will the light go out or does it need to be cleared by a shop? The light was on a month ago and went off for about a week.
Old Jun 6, 2005 | 06:49 PM
ImportKILLER's Avatar
Re: Egr
The symptoms sound like a EGR valve going bad (either stuck open/closed). When my EGR went bad, it would trip the SES and then turn off/on.
The valve is on the driver's side.
After they replace it, the system should turn the SES off after a few miles, but I would just have them clear it anyways.
Old Jun 6, 2005 | 07:21 PM
MarcR94v6's Avatar
Re: Egr
Mine occasionally comes on and then goes back off shortly after. It won't come back until either a day, or a few weeks later and it does the same thing. It's never on for very long. I just hope I don't need to fix my EGR. Right now, I need to replace valve cover gaskets, intake gaskets, remove faulty water pump - install new one, and put in a new thermostat. 3 of which were tried by my dad and I, but we were forced to quit when my dad didn't know what to do. I'll have to try and pay my neighbor to do it.
Old Jun 7, 2005 | 05:10 PM
JB_96RS's Avatar
Re: Egr
Where on the drivers side is the valve? I think the you used to be able to take them out and give it a shake and if you hear it rattle its good if not its shot. The car doesnt run any different
Old Jun 7, 2005 | 05:33 PM
Re: Egr
You are thinking of the PCV valve.
Old Jun 7, 2005 | 05:42 PM
Re: Egr
I used someone's cardomain pic...couldn't find any other ones really quick.
EGR
It isn't hard to replace. The actual part is pricey though.
Old Aug 8, 2005 | 04:20 PM
6SpdLT1Z's Avatar
Re: Egr
Where's it at on a 3.4L?
What are the symptoms of a faulty EGR?
You can clear your code with a OBD-I/II scanner you can borrow from your local autoparts store.
Old Aug 9, 2005 | 12:11 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
Re: Egr
the EGR is on the passenger side of the motor on the 3.4L it is the peice that connects the exhaust manifold to the upper intake manifold
Old Aug 9, 2005 | 03:26 PM
6SpdLT1Z's Avatar
Re: Egr
k right beside the uper intake? I thought that was it.
Old Aug 12, 2005 | 03:01 AM
jonathan_abilene's Avatar
Talking Re: Egr
what store do you go to for the hookup?
Old Aug 12, 2005 | 04:45 PM
6SpdLT1Z's Avatar
Re: Egr
O'Reillys let me borrow one if I gave them my DL. Advanced came out and tried to do it.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
