overheating HELP
Old May 12, 2005 | 06:49 PM
94CamaroDriver's Avatar
overheating HELP
Well the other day the car started leaking antifreeze, so figured it was the waterpump since its orignal 110K mile part so i replaced that, now the car is running hot then overheats when you stop at a light. When driving it stays around 210 degree, stoped it goes from 210 all the way to about 230ish within 2 minutes. Before the waterpump was replaced it ran about 195 degrees all the time. I also replaced the thermostat today. The car is a 94 3.4 camaro.
Thanks ahead of time for any help.
Old May 13, 2005 | 07:43 AM
teke184's Avatar
Re: overheating HELP
bleed air out of the coolant system?
not sure how it's done on a v6...but the LT1 had bleed screws
Old May 13, 2005 | 09:30 AM
EKO's Avatar
EKO
Yea, I've had to drain the cooling system more times than I can remember. But there is no bleed on the 3.4 so what I usually do is let it heat up to about 230ish then let it cool to ambient temp. Take of the pressure cap and top off the radiator and make sure the bottle is full. The thermostat usually has issues opening unless it has coolant on it (it requires a higher temp if its air). Make sure the hose going to the thermostat has coolant in it. Just keep cycling it, heat up then cool off, until the radiator is full and it holds a constant temp. You will usually hear a gurgling sound when it finally pops and coolant flows into the block. It will stabilize eventually.
Old May 13, 2005 | 11:38 AM
I think i have all the air out but i will try what you said. thanks
Old May 13, 2005 | 03:27 PM
Ok, did what you said but didnt seem like any air came out at all??? Also its still doing the same as before?
Old May 16, 2005 | 07:38 AM
EKO's Avatar
EKO
Ok, you aren't going to notice "air coming out." What you will notice is the radiator being low after the engine cools back down. You won't notice the radiator being low while the engine is warm because the cooling system is under pressure, so if you take the pressure cap off, it will be full or dump coolant everywhere. So, if you have waited for the engine to cool completely and it still overheats I would replace the thermostat. If the coolant seems dirty, think about flushing the cooling system. Feel the hoses, if they don't flex when you squeeze them, they could be blocked. Most importantly, make sure it is not still leaking. If my 3.4 is even the slightest bit low on coolant, it gets mad and overheats on me.
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
