Anyone use 15" Drag Radials?
Old Nov 27, 2002 | 07:08 PM
dkeers's Avatar
If so, what wheel are you using. They will be used almost only on the track. I was looking at getting a pair of SLP 16" takeoff wheels and drag radials but I noticed that there are a lot more options in a 15" tire and since I am getting an extra pair of wheels why not 15". I would think that extra width and more side wall would hook better and the whole combination would be lighter right?
I know many 15" wheels won't fit but I could grind the calipers a little. I just want something that is fairly cheap (I'm 19 and on a thinner budget than you can imagine )
Old Nov 27, 2002 | 07:52 PM
V6toZ28's Avatar
Try the Centerline Convo Pros. 15x8.5 w/ 5" BS .. no ginding required .... You can get them on Summit for a pretty reasonable price.
Here's a pic of them on my car.
Good Luck
Old Nov 27, 2002 | 09:15 PM
BISHOP's Avatar
I'm using 325x50x15 BFG drag radials mounted on 15x8 Weld Prostars with a 5 1/2" BS.
Old Nov 28, 2002 | 05:02 PM
dkeers's Avatar
Thanks for the help. Those wheels are a little more expensive than I had planned on. I was thinking something closer to the price of SLP take-offs (~$50 each). Are a set of steel wheels like the Nomad-II or AR-767 that I saw in Jegs a bad idea? Can I make them work? Like I said the budget is really tight .
EDIT
They will be for track only so I'm not too worried about them looking good. Black painted steel would be fine with me if it will work.
RUENUF
Mar 13, 2016 03:37 PM
HAWG
Sep 25, 2015 11:41 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
