Need advice on aftermarket lower control arms
Old Dec 3, 2002 | 08:42 PM
2001Z28's Avatar
As you might have guessed, I drive a 2001 Z28.
I've done a little poking around and the best bet I've found so far is the Spohn LCA w/poly bushings ($145).
I don't want road noise to increase a whole lot because it's a daily driver. I realize this will cost me some performance, but I'm just looking for something that will help decrease body roll a little bit.
Any advice/experience with this would be greatly appreciated!
Old Dec 6, 2002 | 01:53 AM
stik6shift98's Avatar
go with bmr.....
Old Dec 6, 2002 | 05:18 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Thumbs up
Another vote for BMR, I have the boxed LCA's with poly bushings, and the trick is to grease the poly bushings, and the bolt with pure silicone grease BEFORE installation, then use a high quality synthetic gease pumped into the zerk fittings. You will have no trouble with any squeaking.
You do pick up some additional road noise, however the pluses of the performance gaines in handleing out way any minuses.
JMHO
SteveC
Old Dec 6, 2002 | 05:55 AM
mrgto's Avatar
www.bmrfabrication.com
Old Dec 6, 2002 | 08:51 AM
casebuzz's Avatar
How are LCA's going to significantly reduce bidy roll? Shouldn't this guy be looking at springs/shocks and/or sway bars if that's what he wants?
Old Dec 6, 2002 | 07:04 PM
2001Z28's Avatar
Thanks everyone for the advice.
This guy is not looking to lower his car, get new springs etc. I realize that there's better things out there but I don't want to spend a fortune and I don't want to ruin the relatively smooth ride I have right now.
Plus, I don't really savor the idea of hitting my head on the roof every time I go over a bump ...
I'm just looking at something small that I can do that will improve performance a little bit.
The car is still under warranty and I don't want to modify it too much.
Old Dec 6, 2002 | 07:33 PM
LS1CamaroSS's Avatar
I have Metco lower control arms, I don't havea any problems...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
thenewkid
Nov 27, 2014 09:41 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
