whats a ta cover???
It puts pressure on the bearing caps on hard launches, looks great too. You can also get an optional stud kit with it.
www.taperformance.com/gm.htm
It is a deeper aluminum cover, that applies pressure to the carrier bearings, so they dont "float" upon hard acceleration. As said above, it also has a drain plug for convenience.
SteveC
SteveC
for 150 bucks, you get an unrusted cover, suposedly designed to disipate heat, stronger, and has the fill and drian plugs. When i put in my 4.10's i am going to throw on a G2 rear end girdle. Same thing just different company. I think it is worth it.
Easy. www.installuniversity.com has a great guide.
Bails098
Aug 17, 2015 05:15 PM
CARiD
Jul 7, 2015 08:19 AM
i dunno how, but supposedly it holds the rear end in a lil better. and gives you a drain plug if i remember correctly. also looks better.
