quick help with oil press problem?
Old Dec 2, 2002 | 04:46 PM
2000 supercharged TA's Avatar
i have just recently gotten my motor rebuilt and 1 have about 3k miles on it. when i got it back it had about 40 maybe a little more pressure. now it seems to be droping to 30 and some times a little bit lower at times i see 20. and when i rev it, it does not go over 40. how can i get my oil pressure back up? i do have a decent size cam and heads but i dont think that has any affect on it but i could be wrong. any help would be greatly appreciated
Old Dec 2, 2002 | 05:04 PM
NEWBIE T/A's Avatar
Talking Yecch !!
Oil pressure, or lack thereof, is one of my pet peeves !!
Too great a clearance in the cam bearings or main bearings can cause low oil pressure, as well as overheating or too thin a viscosity of oil.
For what it's worth, go about 1/2way down here :
http://www.ls1info.com/article.php?sid=202
for minimum oil pressure specs.
What did it run before ?
Is it full of oil ? (A logical but often overlooked place to start.)
If it is nothing "simple", then you may want to visit with your friendly engine rebuilder for his thoughts - I assume he covers it with some sort of a warranty.
Good Luck !!
Britt
Old Dec 2, 2002 | 05:22 PM
right now it is running most of the time at 30 it had 40 or barely more when i first got it back
artic94
Jan 17, 2015 11:19 AM
Jessie4tin
Jan 7, 2015 08:53 AM
97SSdude
Dec 31, 2014 07:43 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
!!!TED!!!
Aug 27, 2002 05:41 PM
