Help(23 pounds ft-lb is ?? in.-ibs)
Old Jun 9, 2003 | 11:48 PM
RobZ's Avatar
Question Help(23 pounds ft-lb is ?? in.-ibs)
I bought a torque wrench that is in.-ibs,to torque the ls1 rockers.I also found that I bought the wrong one but was wondering if i could convert it Ft-LB....This wrench goes from 120-960 in.-ibs.Now i need to know what 23 pounds ft-lb torque is in in.-ibs.Can one of you guys help me out here.I dont know the correct formula to convert this.thanx
Old Jun 10, 2003 | 12:27 AM
ChrisLS1Bird's Avatar
Shouldn't it be as easy as dividing by 12?
Inches..to feet..
Just look at the numbers..the range is given in perfect multiples of 12. A range of 10 ft-lbs to 80 ft-lbs sounds reasonable to me.
Old Jun 10, 2003 | 12:33 AM
Oh, sorry..23 ft-lb = 276 in-lb.
ft*12=inches
Old Jun 10, 2003 | 02:33 PM
RobZ's Avatar
So do you think its 256 inches?Sounds right tho.
What do you think about this conversion fromula.
1Nm=0.73756 ft-LB,What should i multiply that by?
Old Jun 10, 2003 | 04:41 PM
WhoBetter?'s Avatar
It's the same as converting inches to feet, so 120-960 iinch pounds is 10 ft#-80 ft# and yes 23 ft# times 12 is 276 inch#.
Old Jun 10, 2003 | 10:08 PM
Multiply feet by 12 to get inches..
divide inches by 12 to get feet..
So 1Nm=8.85072 in-lb
Old Jun 11, 2003 | 12:56 AM
RobZ's Avatar
Thumbs up
thanks I got it,torqued them down.
NewsBot
Sep 14, 2015 09:20 AM
NewsBot
Sep 14, 2015 08:50 AM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
NewsBot
Mar 30, 2015 12:40 PM
