Transmision question for the m6 guys
As if I were going to launch in a 1/4 mile Im having a problem when I let off the cluth at about 2300 rpms I can here something clunking. is that associated with the torque arm or a transmission mount.
see I hit the gas comming onto the freeway one time and I accidently went from 3 to second gear (miss shift) the tires started to bounce I disenged the clutch and put it in the proper gear. I wonder if that tore the transmount.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
