1st time at track-3rd gear
Old Jun 7, 2003 | 05:40 AM
CHRISCAMARO's Avatar
1st time i tested my 02 Z28. Ran 13.98 with the ETS on. Got to 4th gear.
Then ran 14.01 without the ETS-once again to 4th gear.
Finally, ran 13.91 with the ETS on and did not shift to 4th- left in third (red lined for the last 50 feet maybe).
Question-do you guys recommend turning on or off the ETS? And do you get to 4th gear or only third?
thank you foryour insights, i am new to this. what a lot of fun. What next to make me faster? (2002 LS1 V8 w 6 speed; Free ram air, K&N filter, MAF cutout, Hypertech computer override, Ram Air Lid, FLowmaster) I can't believe i ran so slow! i need to go faster!
Old Jun 7, 2003 | 09:32 AM
PhantomTA's Avatar
Moderator
your best times will come with the traction control off.. and in 4th gear
Old Jun 7, 2003 | 12:38 PM
96SFLZ's Avatar
I agree, ASR off and shift into 4th. If you leave it in 3rd, you should be bouncing off the rev-limiter for the last 150-200 feet or so...I know I would be.
What were your 60' times? And what were your trap speeds?
Old Jun 7, 2003 | 03:38 PM
silversupersport's Avatar
"what next to make me faster"
i think alittle more practice and you should be able to get to the mid 13's or lower. also i noticed a small burnout helps even with street tires.
Old Jun 8, 2003 | 01:57 AM
AL SS590 M6's Avatar
Moderator
What he said!!!
Old Jun 9, 2003 | 09:17 PM
thanks all for your help.
at what points should i be shifting (on the tac) in each gear? I was running it up to the first red line-is that too high?
thanks again-newbie
Old Jun 9, 2003 | 10:54 PM
CamaroBoy96Z28's Avatar
ASR being off is a MUST. It takes power away from your rear wheels as the car tries to regain traction. Dont want that. Vary shift points and see what works.
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Jul 4, 2005 05:00 PM
