idle adjustment screw?
Old Jun 10, 2003 | 12:19 PM
hrtbeat2's Avatar
Question idle adjustment screw?
I was looking @ my TBody, but didn't see any thing. mine seems to idle i think to high 900 its a 6-speed, ???
Old Jun 10, 2003 | 12:35 PM
sleeperZragtop's Avatar
It's there...look at the TB stop where it sits...it's underneath that...your best bet is to turn the screw around so it's easier...you may need to remover the TB....good luck
Old Jun 10, 2003 | 05:10 PM
ratio411's Avatar
Be careful!
I have the same problem with my M6. It idles too high for my liking.
I did what you are thinking about and adjusted the throttle plate closed further, but ran into a problem...
The plate was apparently already adjusted as closed as it could get, my further adjusting caused the plate to bind in the TB bore. This was a scary thing. The pedal was intermittantly hard to push, so hard that it would go from nothing to floored trying to get the car moved, then would be very erratic afterwards.
I had to put it back where it was.
In my search to lower my idle, it has been taught to me by folks that know, that the computer controls the idle anyway and anything you do to counteract that mechanically, the computer will just adjust it out and raise your idle back up to where it thinks it should be. So the only real way to lower the idle is to program the computer to your wishes.
$ucks, but true.
Dave
Old Jun 10, 2003 | 06:56 PM
hrtbeat2's Avatar
Thanks for your input.
Z28Freak86
Apr 28, 2015 10:35 PM
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
edman
Jan 25, 2015 02:41 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
