question regarding subframe connectors
Old Jun 13, 2003 | 04:27 PM
96Z28man's Avatar
what is the difference between bolt ons and weld-ons??? also, are kenny brown dd's bolt ons or weld ons???
Old Jun 13, 2003 | 06:11 PM
jd13's Avatar
Bolts ons have a chance of coming loose over time. I prefer the weld ons myself. And I'm pretty sure the Kenny Brown's are weld ons.
Old Jun 14, 2003 | 02:25 AM
silversupersport's Avatar
yup the kenny browns are weld on, but iif you want bolt on dd style you can get slp's but they do cost alittle more.
Old Jun 14, 2003 | 04:24 AM
TerrorDome's Avatar
i have bmr tubulars and they're welded.
if you do that, make sure the installer knows how to put them in and has had experience doing others correctly.
Old Jun 14, 2003 | 06:53 AM
98BlueWS6's Avatar
Why how can they be insatlled incorrectly? Also the instructions that came with mine I have lost. I have pictures of someone elses installed. Is there anything specific that I need to know. I also have the BMR tubular ones.
Old Jun 14, 2003 | 11:58 AM
kinyu's Avatar
The car has to be perfectly level. So you need somewhere that has a car lift. You also have move around while welding under there. If you concentrate in one space for too long, you could burn the inside carpet.
Old Jun 14, 2003 | 04:46 PM
mr_muff's Avatar
the suspension also needs to be loaded right?
Old Jun 14, 2003 | 06:03 PM
RS Dragster's Avatar
Yes. Bottom line: have the car level, and have its full weight on the wheels. Make sure you scrape off the paint where you're going to weld, and go at it. My dad did mine and they came out great. He's not a pro welder, but he's done it enough to know what the hell he's doing.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Jibberish18
Aug 28, 2002 12:46 PM
