rear end questions...
Old Jun 13, 2003 | 06:22 PM
camaro322hp's Avatar
how often do you guys change your diff lube? i have 62k, and lube is original as far as i know.
is there a drain plug on our diffs? or do i just have to pull the cover off to drain it? all i can see is the fill plug.
if i do have to pull the cover off, will there be any problems reusing the same gasket, or should i use a new gasket, or RTV?
BTW, i'm the original owner, and car has not been driven hard at all. never been to the strip.
thanks in advance...
Old Jun 14, 2003 | 02:16 AM
silversupersport's Avatar
haynes manual says to change diff fluid every 30000miles or 2 years whatever comes first. there is no drain plug on the axle, you cant re use the gasket if there even is one. i use rtv sealant on my truck because they dont make gaskets for it so it should be fine for our cars.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
