3X3 fernco or the smooth bellow
have you gotten it on at all? if not, then try boiling it in a pan of water for about 5 min. i used a hair dryer on mine, but the boiling method sounds better. after that it ought to slip right on the tb. when i put it on with my TSP lid it wouldn't let the lid seat properly so i trimmed about 1/4" off of the maf side of the fernco, and now it fits perfect!
good luck
good luck
I just got my Fernco 3x3 yesterday but am waiting until I get my lid to put it on. It does look a little stiff, and that it might crack the lid if you rev the engine. Maybe the boiling softens it up a little. It sure does look a lot better than the SLP, it's cleaner looking. Can't wait to put it on!
I just put my frenco on yesterday and let me tell you it wasnt easy. I had to have someone help me. If you plan on getting the frenco i would trim it down a bit before installing it otherwise it wont fit right. My TSP lid doesnt sit all the way back like its supposed to. But i am going to trim it down to fit better. For $3 its a good mod.
How about the Austin Bellows. It comes in different colors and the plastic is very pliable. It sells for $39.
www.buickwe4.com/pic/DSC00021.jpg
www.buickwe4.com/pic/DSC00023.jpg
There's also the direct-flo bellow at http://www.ls1motorsports.com/ that is angled to work with our cars. They say it works especially well with the WS6 TA since the lid sits a little higher. It's $50...but, if you're looking to spend the money, I recommend them.
Try this sight, it is only $13, and fits well, you want the "4"to31/2" hump hose.
http://shop.airflowonline.com/Mercha...tegory_Code=HH
SteveC
SteveC
SteveC
SteveC
SS1LE02;
You need at least one rib in the hose for proper flexation between the engine and MAF. The one rib WILL NOT create that much turbulance compaired to the stock bellows.
SteveC
SteveC
