View Full Version : Forced Induction
- mass air flow
- stock turbocharger
- What gears should i go with
- Tuning question?
- Manifold Selection
- alcohol injection setting
- water injection
- What turbo kit would you buy?
- Parts List for fmic
- Noob question
- stock or ported intake manifold(LT1)
- mass air flow
- Please Help! i need help tonight/noww, installing pulley
- PTK + Twin IC Pressure Drop?
- 4 bolt splayed caps on rebuild
- supercharger questions
- Injectors?
- aeromotive fuel press. regulator users inside please...
- Cooler Piping
- Installing a turbo timer. Need some help with finding the ignition harness.
- Does boost change the basics, like head flow?
- lt1 turbo tuning problem?
- 94 V6
- what kind of power are you guys making with 76mm turbo
- opti spark vacuum lines/pcv, valve cover lines
- Just got a Weiand 142 supercharger, HELP!!!---
- Vortech & intercooler & pipe size
- D1SC Oil Change
- Need Advice on Combination
- 3bar MAP over 15psi?
- twin turbo complete kit for sale, CHEAP
- Building 69 Small Block to Include STS Turbo (8# boost)
- turbo and rear gears
- pro charger
- intake tube
- How Much is Too Much HP?
- Cost of a Supercharger? What goes with it?
- d1sc 383 12lbs of boost =....
- turbo and tuning...
- some help
- NEED your opinion
- Looking to trade. 2600$ wedding ring set for p600b or V-1 S-trim
- Problem with procharger pulley
- Problems with headers on STS Turbo setup
- LT1 supercharer questions....
- Custom/modified fuel rails?
- Turbo Header question.......
- Where to spray N2O into turbo/intercooled engine?
- New cam and heads for S/c or nos
- Need input: CR for nitrous & 6 psi
- turbo kit design...
- P-1SC vs. D-1SC
- head gaskets
- I need 30 lb injectors and im a cheap bastard
- procharger
- FS Twin Turbo headers for LT1 or SBC--CHEAP
- anyone with a paxton balldrive intested in...?
- Ignition for high boost
- guaging interest ATI P1sc stage 2 kit *NEW* with PICS
- FMU stuck- rebuilt...Question!
- 75lbs inj 4Sale
- Serious question about STS Turbo.
- Intercooler mount pics
- turbo set up?
- super chargers
- A few questions about supercharging
- Heads Up. Procharger COG Drive Setup. 6 Hours left..
- blown 383 cost
- Turbo Street cam choice
- Procharger In 2000 Ss
- methanol injection or intercooler
- Does this calculation sound about right?
- Vortech with Crank Trigger ???
- ProCharger P-1SC-1 install
- Max out your 6 Rib Pulley Setup. Procharger 2.5" 6 Rib Pulley
- No Slip Procharger Pulley Setup. ASP COG Drive Setup. Fixed Belt Problem
- Rear Mount Turbo?
- FMIC - Yes or No?
- HiTech Dyno just north of Minneapolis. Anygood?
- stock z wtih sc/pc
- Road Course Racing with a SC
- Injector size help
- Need a complete motor with blower?
- LS6 and Super charger.WOW
- anybody useing a filtermag magnet ???
- tune/fuel delivery for p600b.
- powerdyne set up ????????????'s
- 6-71/8-71 Supercharger
- Work in progress...long... 56K users beware!
- experienced/educated members of board please lend some intellect. p600b
- which igniting for p600B
- New 42# injectors for sale $300+shipping
- Which one of you guys is familiar with FI & Alcohol?
- 99 camaro ss
- Powerdyne Owners Within...
- If anyone is looking for a supercharger
- Supercharger/Tranny issues
- Turbo setup
- Vortech Aftercooler
- Looking for S-trim plastic blower output to intake tube... Anyone?
- Single belt?
- I need a list of parts to supercharge my '87 firebird
- P600B Install Instructions and Parts List
- used s/c
- Looking for markinkc69z
- T rex pump
- 630 RWHP fuel pump suggestions
- cam questions? with boost
- What Air/Fuel Ratio for Supercharged LT1
- air discharge
- 94 Z Time For Rebuild And Supercharger ???help People..
- Running Rough
- Spark Plug Recommendations for AFR 195's
- will this work?
- FS FAST/SpeedPro ECU
- Smoke under boost
- Advantage to long tubes with turbos
- Ati Procharger 2 Core I/C Install...Pics
- Questions about tuning speed density for boost.
- Vortech aftermarket suppliers???
- LT1 Fuel System Question
- Procharger instalation instructions?
- looking for used s/c (ATI, vortech)
- Dynoed, now have a fuel issue
- GMR speed TT ls1 kit pics
- powerdyne or vortech s/c
- 994rwhp 863rwtq LS1
- Supercharger vs Engine Question
- latest dyno results
- Turbonator?
- Vortech & Procharger pulleys
- New Garrett gt42. Turbosmart Progate
- Need advice on my clearances
- Newbie to supercharging needs some pointers
- Turbo Newb ?'s
- Does a supercharger damage a throttle-body?
- Long term effects of 8-9 pounds of boost....
- Inter cooler tubing
- Sacramento Turbo Tuner???
- Idles about 2K when moving??
- D1SC/Engine Trouble Need massive help
- Bov Placement...
- Best place to look for buying FI
- Upgrading ATI pulleys/boost...
- Merry Chistmas Turbo Question
- Turbo Lt1
- Turbocharing/SC'ing a LT1
- Header coatings?
- What distributor to run with FAST on a BBC?
- want 2 twin turbo lt1
- Choosing between the F1, F1R, and F2
- Anyone relocate their battery?
- Any LT1 owners need headers for DI turbo kit?
- A few sts questions
- Who has removed a supercharger?
- Supercharged 350 to supercharged 383 boost ??? please...
- Pistons 2618 vs 4032
- Is this for real??
- p600b procharger, injector size, spark plugs..
- Incon Twin Turbo Kit for sale
- Anyone else have their intake elbow blow off?
- sooo close, twin turbo buildup
- Who really know about wastegates?
- Couple of Turbo Questions
- Turbo i recently got
- Forged pistons and Forged rods + 12psi of boost
- help me select a cam.
- Any air to water cooler guys
- I just bought a 00' Z28, now I'm considering a Cold Air Intake. Suggestions anyone?
- What boost is needed for 500hp?
- Anyone using ZEX Spark Plugs?
- Intercooler mounting
- Stock heads for turbo?
- 908rwhp 908rwtq Speed Inc. single turbo LS1
- vortech vs. procharger
- Procharger pulley problems
- Lt1 S-trim Guys
- Quadrajet and blow-through blower
- look here..
- I might be joining you guys next season!!!
- 94z a4 rebuild time.....
- Downside to cog setup???
- Inercooler/methanol injection
- 228/232 cam
- SN93 power
- T3 turbine housing A/R question
- Compression ratio on blown Big Block Chevy
- ATI compressor maps?
- SN 93 for $100
- F.I. compression ratio issue
- choosing injectors, suggestions?
- New ATI 4.5" twin intercoolers
- Supercharger vs. Turbo psi
- K&n Cai
- Procharger D1 Bracket with both Pulleys and Tensioner For Sale
- JE pistons/rods and turbo for sale
- Blower Advise Please
- Monoblade guys
- Turbonator
- Ltx + Sts
- Hi RPM Idle after Boost Application
- Water or Air
- Head Studs
- Is 10:1 Compression Lt1 To High To Run Supercharger??
- home made rear mount turbo kit
- ATI Procharger
- procharger
- question about mains in LT1
- Coating ROSS Blower/Turbo pistons
- questions bout my greddy BOV
- Building a 355 for Boost?
- Vortech blower, same on LT1 and LS1???
- which supercharger for my car
- Wastegate Sizing???
- Mahle pistons?
- Supercharge
- 383 Builders, I need Feedback Please....
- water pump flow rating?
- Twin Turbo'ed LT4 Tuning Question
- Question about building Twin Turbo'ed LT4
- dummy turbo???
- it happened
- Something wicked coming!
- What happens if...?
- sts kit on ebay
- Y2k turbo
- Partially filled block with Boost?
- Turbo Exhaust Set-up?
- new ignition setup and intercooler
- ATI race BPV or Super Mondo BPV? Which 1 and why?
- High Boost - Forged rods/pistons only
- Supercharger and Flows
- stock crank+boost+rpm=?
- FMIC placement in a 96 T/A
- how much power with a powerdyne???
- Vortech Aftercooler Opinions
- LE1/2 + Supercharger?
- where to get procharger pulleys
- NGK iridium plugs are fine for a supercharger right?
- tire choice and gear
- Trick Flow heads
- Versafueler?
- lets build something to kill the z06, viper, shelby, & most anything else!
- gains?
- 80lbs+ injectors
- Throwing boost on a stock bottom end..
- Catastrophic Opti failure...pics
- BLOWN & SPRAYED 383. Need Help!!!
