Which one of you guys is familiar with FI & Alcohol?
Old Jan 8, 2006 | 07:19 PM
LameRandomName's Avatar
Just trying to figure out the pressure needed to get a specific job done.
357 CID LTx engine
3.50" stroke
6.00" rod
Compression in 10 - 11 range
Blower: Vortech X-Trim
Fuel: E85 (85% Ethanol + 15% Gasoline
Heads: Trick Flow LTx with LE-3 level porting, "Over 200" AFR's or something else with airflow in that range.
HP Goal: 750 flywheel.
Questions:
1) Approximately how much boost would be needed to get the job done?
2) Will the heads I mentioned get the job done or do I need to plan for something $bigger$, such as the 18X?
Old Jan 9, 2006 | 04:26 PM
engineermike's Avatar
Re: Which one of you guys is familiar with FI & Alcohol?
I'm betting you could get there with <15 psi and AFR210's.
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
Red97LT1
Aug 7, 2002 05:45 PM
