Injectors?
Injectors?
Whts up, I have an 01 Z with just long-tubes,converter,and flexplate. I ordered a D-1sc and Im going to run 8lbs. What type of #'s do you think I will make? Also what size injectors should I go with? Should I do a fuel pump or could I wait a little while?(Will be forging it in a little to run more lbs.)Thanks for the help.
Re: Injectors?
I have no idea on power #'s, but fuel is the second most important part of a FI build (right behind the tune). If you are going to go more boost later, get 60# injectors, and do the fuel pump. That should keep you okay up to the 600-650 rwhp range.
As a guess, maybe you'll be in the mid to upper 400's rwhp.
autoxr166
Sep 25, 2015 04:21 PM
