p600b procharger, injector size, spark plugs..
Everyone asks these question but I still get confused. Will 42lb injectors work with my, and what plugs do I need, I search, but there are a million dif. answers. Let me know.
Sam
Sam
Re: p600b procharger, injector size, spark plugs..
yes 42's will work, but you need tuning...run the ngk tr-6...they are cheap and are a heat range colder (colder = safer)...you will need to add an intank fuel pump...ive got the walbro 255lph...seems to give me enough fuel for what im doing....good luck
42# injectors will give you room to grow, but if you have high HP plans you will outgrow these too. I think the previous post meant that you'll need a bigger in tank fuel pump.
Will I tune from Madz28 work for the injectors, if I call him and tell him that I have 42lb injectors, will his tune work, or is that not the tune you are talking about?
10-31-2016 11:09 AM
