Turbo setup
Old Jan 5, 2006 | 10:23 AM
InSaneRed94Z's Avatar
Turbo setup
Right now im rebuilding my motor to 355. 4 bolt mains fully forged, i also got a big holset turbo off of a dodge ram desiel truck, and a cc306 cam on a 114lsa, im wondering if anyone else has done a 355 turbo with cc306, keep in mind my pistons are 32cc dish so im gonna be running quite a bit of boost, any suggestions comments or ideas on what you guys would recommend
Old Jan 5, 2006 | 10:47 AM
detroit1994z28's Avatar
Re: Turbo setup
I'm running a t67 turbo with a stock engine and hot cam similar to cc305. You should be okay.
Old Jan 5, 2006 | 11:27 AM
mn_vette's Avatar
Re: Turbo setup
What's the compression ratio for the engine? How much boost are you planning on running?
I would think you would need a bigger turbo than one off of a diesle pickup truck. They are rated for great torque, but the key is HP and air flow. Do you have a compressor map or something?
The cam should do just fine, but if you are planning on running bigger boost you might want a more agressive cam. Just some stuff to think about.
Old Jan 5, 2006 | 12:36 PM
SMOKNZ's Avatar
Re: Turbo setup
The stock Turbo Diesels turbos have a compressor map that closely resembles a T60. Hardly "Huge"
Old Jan 5, 2006 | 04:15 PM
onlyone07's Avatar
Re: Turbo setup
Ya those turbo's work great on 2.3L mustangs. I had a Holset on one of my Mustangs I used to own. They're also good for STOCK 5.0's. I hardly think it'll work to well on a cammed LT1.
Old Jan 5, 2006 | 05:15 PM
ronbros's Avatar
Re: Turbo setup
I would put it all together, with a T4 flange , run it and tune it , you can always put more turbo to it later after you have everything else figuered out , a Holset off a 5.9 cummins should make 475-500 whp, and I am from the, use a stock cam school, until your sure you need more. if that 306 means seat to seat duration YES, but if it means at .050 lift I think no I wouldnt use it. to bad it wasnt a twin cam then you could spread the LCs out. stock cams on the street work quite well, but maybe your planning a 1000hp !! Ron
Old Jan 5, 2006 | 06:52 PM
96PTKZ28's Avatar
Re: Turbo setup
I would say atleast a T-70. If you want to get a little more crazy in the future go with a T-76. Talk to jose at www.forcedinductions.com.
Old Jan 6, 2006 | 12:51 PM
Chrisbequick's Avatar
Re: Turbo setup
I've got a 76.5mm HKS turbo on a 355 with a Comp 305 grind. It runs okay and makes 569 at the wheels at 9 psi, but I wish I had gotten a turbo cam when I built the motor instead of using what I had. The boost comes on slowly on my setup.
-Chris
Old Jan 6, 2006 | 06:12 PM
wingnut's Avatar
Re: Turbo setup
I have an LT1 turbo cam for sale:
224/224 @.050 114 and 568/568 lift
wingnut
pm me if interested.
Old Jan 7, 2006 | 01:15 AM
engineermike's Avatar
Re: Turbo setup
What lobes are those, wingnut?
Old Jan 7, 2006 | 04:20 PM
wingnut's Avatar
Re: Turbo setup
I am not sure if I am answering the question right, but
@ .050 int. 2deg btdc 42deg abdc
exh 50deg bboc 6deg atdc
specs are for cam installed @ 110 intake center line
custom comp grind 3192s / 3192s hr114+4
s/n 0962
part# 01-000-8
Wingnut
Old Jan 12, 2006 | 05:46 PM
dobe's Avatar
Re: Turbo setup
what holeset turbo?
guy near here was running one into the 9.4x's on a homebuilt/junkyardsetup... of couse this may be a bigger turbo then what you have but who knows.
i would use another cam
9t4lt4z28
Oct 2, 2015 10:28 AM
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
