Partially filled block with Boost?
Old Nov 20, 2005 | 03:38 PM
1995ta's Avatar
Anyone currently using a partially filled block and running boost as well? My 383 is filled to the bottom of the freeze plugs and will have an F1C procharger on it (boost undecided) I was just wondering how hot it may run? I will be using an air to water intercooler...
Bret
Old Nov 20, 2005 | 05:16 PM
rskrause's Avatar
Moderator
Re: Partially filled block with Boost?
I don't have heat related issues.
Rich
Old Nov 20, 2005 | 05:24 PM
1995ta's Avatar
About what temperature do you run at?
Old Nov 20, 2005 | 05:30 PM
rskrause's Avatar
Moderator
Obviously, depends on conditions. But I usually see 185-195 degrees with an electric WP and a 160 thermostat.
Rich
Old Nov 20, 2005 | 06:23 PM
ramair96ws6's Avatar
Rich
what are your oil temps though?
Old Nov 20, 2005 | 08:43 PM
rskrause's Avatar
Moderator
Dunno, never checked. But I always subscribed to the following as far as desired temps. The oil should be hot, the block warm, and the air cold. Obviously, oil can get too hot though.
Rich
Old Nov 21, 2005 | 10:28 PM
blown69nova's Avatar
I just talked to an area machine shop and he suggested a partial fill also. He says it's fine for the street. He seems to think it helps cooling because it keeps more coolant around the cumbustion chambers. He also added that aftermarket blocks use more iron/less coolant in the area you fill. Just some thoughts, what do you guys think?
Old Nov 21, 2005 | 10:56 PM
1995ta's Avatar
Exactly what my machinist said to me.
(Marlar Racing Engines)
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
