FS Twin Turbo headers for LT1 or SBC--CHEAP
Old Jan 23, 2006 | 04:34 PM
will62085's Avatar
Moderators...this is specific to FI, thats why im posting here...
Im selling my headers from my twin turbo project, they are 1 5/8 primary tubes with 3 inch collectors, Round port 1/2 in. thick mild steel flange will fit LT1 and standard gen I small block chevy. 3/8 in. T4 flanges, and 38mm wastegate flanges. 16 guage mild steel primaries and formed collectors
these will not work on a 4th gen without extensive modification to the upper core support, or at a minumum radiator relocation, they should fit any older larger car with standard SBC though, but i CANNOT garruntee fitment on any vehicle! see link in my sig for pictures of the headers on and off the car
Now, for the bad part, the inside of the collectors leak, and some of the primary tubes are leaking around the head flange, All the primaries are sealed and do not leak, the wastegate flanges do not leak, and the turbo flange weld does not leak. they WILL need to be welded up before they can be used, the leaks are easy to find as there is carbon build up around each leak. You can weld them and then use them on your project, or just use them as a jig, and copy the design for your own setup...plug access is tight, but is do-able. they will clear spark plug boots as well with plenty of clearence. they do not however clear the temp sensor plug on the driver side head...they clear the sensor, but there is no room to plug it in, i have been using the temp sensor in my water pump for this...
Im selling these for less than the cost of materials, $400 shipped! they cost me $450 to make!
Head flanges, $80
Turbo flanges, $80
Wastegate flanges, $50
Tubing and collectors, $240
Old Jan 25, 2006 | 08:24 AM
RealQuick's Avatar
Re: FS Twin Turbo headers for LT1 or SBC--CHEAP
Whats the new project for you?
Old Jan 25, 2006 | 10:24 AM
will62085's Avatar
i ordered some slip merge collectors...and a TIG machine...same setup, i just was not happy with the headers
Old Feb 3, 2006 | 08:29 PM
94 BIGRED's Avatar
ttt
Old Feb 3, 2006 | 11:34 PM
lunati397's Avatar
I will find out when i get home if I can get this done and PM you I want to take a look first I am in Iraq right now but im leaving in the next few days
also I am very interested in your accesory setup do you think you can send me a bluprint or somthing for that it looks custom
Old Feb 4, 2006 | 12:20 AM
will62085's Avatar
it is custom, im working on getting a cad file for it and either laser cutting the peices to weld, or maybe cnc milling one from billit
Old Feb 4, 2006 | 06:22 AM
lunati397's Avatar
I just want to get home first before i purchase these I have a 383 LT1 in a thirdgen camaro setup for Forced Induction in my car right now and I have tons of room enough to hide a small midget mechanic in my engine bay If you can trace that bracket onto a paper and send it to me with the manifold I am sure i can have one made up. I would like to get ahold of you on IM or phone sometime when i get back i have a few Questions about your setup I really hope you arent in a huge hurry to sell this because it will be about a week or so until i get home from Iraq.
If you really want to get one CNC from billet i know a few guys that work at Mallory billet and might be able to get a deal by buying a few at a time or I can have it done by a buddy of mine that works at metals tech on base
Old Feb 4, 2006 | 10:36 AM
will62085's Avatar
i can have it done in billit at my school, i just have to find the time...haha, ya just shoot me a pm when you getback and ill give you my phone number, tracing that bracket shouldnt be an issue though, its really pretty simple piece, the hardest part was getting the spacing right
Old Jun 4, 2006 | 01:22 PM
BLWN1's Avatar
Wow, I just sent you a pm and found this, did these sell?
Old Jun 4, 2006 | 02:34 PM
will62085's Avatar
no, they leak and will need some work to make them useable, thats why im selling them for the cost of the materials...there sitting on the shelf in my garage right now
LeftoverChinese
Jan 14, 2024 03:03 PM
Brady
Jul 29, 2002 10:30 PM
LT1runner
33
Jul 24, 2002 01:19 PM
ced8
Jun 24, 2002 11:11 AM
