Head Studs
Old Nov 28, 2005 | 10:15 PM
Kevin Blown 95 TA's Avatar
Head Studs
Can anybody tell me if it is possible to get the heads off a studded block while it's still in the car. Mine is a 95 TA. Thanks.
Old Nov 28, 2005 | 10:26 PM
Lonnie Pavtis's Avatar
Re: Head Studs
Yes,
They will come right off with the studs in the block.
Old Nov 29, 2005 | 06:04 AM
Re: Head Studs
Thanksfor the quick reply!!!
Old Dec 1, 2005 | 01:23 AM
Camaro_SS/R's Avatar
Re: Head Studs
With the new studs you can also pull the studs off with an Allen wrench. Then the heads can come off without any clearance issues.
Old Dec 1, 2005 | 10:04 AM
Re: Head Studs
Hugh, are those ARP studs?
Old Dec 1, 2005 | 11:13 AM
Re: Head Studs
Yup. It should have a hole on top of the stud for an allen wrench to go in.
Always always always put the proper thread sealant for the ARP head studs!!
cheers
--Hugh
Old Dec 1, 2005 | 01:04 PM
Re: Head Studs
Thanks again - that's a good improvement. I have the ARP thread sealer.
I always have a problem of whose torque specs to use. There's GM, ARP, AFR, & sometimes gasket maker. What does everybody else do? I'm going with the Cometic gaskets this time.
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
May 27, 2015 09:53 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
95chwagon
Jan 13, 2015 09:19 PM
Catmaigne
Dec 25, 2014 12:16 PM
