908rwhp 908rwtq Speed Inc. single turbo LS1
From: I reached back like a pimp and smacked that LS1....
Today I just finished up tuning a 6-speed F-body we built with our single turbo system (using TTI race hot parts).
370ci iron block, out of the box AFR 225's, 225/225 113lsa cam, Innovative GT76 turbo with 1.15 R-trim hot side.
Boost was 19psi at peak torque, 18psi at peak horsepower. C16 fuel, 21 deg timing @peak torque 23 deg timing @peak horsepower.
Engine management is BS3, used in conjunction with our plug and play piggyback harness which allows the stock pcm to run the gauges, and if so desired, fans, fuel pump, reverse lockout.
http://www.ls1speed.com/pictures/turbo12_12.jpg
Re: 908rwhp 908rwtq Speed Inc. single turbo LS1
Originally Posted by RealQuick
Nice! You have a lean spot at 4k rpm though...you may want to look at that.
Here is a plug from that pull.
www.ls1speed.com/pictures/turbo12_121.jpg
www.ls1speed.com/pictures/turbo12_122.jpg
Originally Posted by INTMD8
Thanks for the tip. Air fuel on the BS3 showed 11.9-12.0 throughout the entire run.
Jon
So is the BS3 wrong or the dyno's WB??? I cant tell form the plug the difference between 12.0 and 13.0....Either way, I am sure you know what you are doing, just thought I'd point it out.
Jon
Jon
stockssn2o
May 25, 2015 08:54 AM
