Turbo i recently got
Old Dec 18, 2005 | 02:31 AM
InSaneRed94Z's Avatar
I just pruchased a basicly brand new turbo off of a cummings desiel dodge motor the trucks a 2004, bought brand new then wrecked after like 20 miles, guy took turbo off and set aside, and i picked it up, has anyone done a custom turbo setup with one of these turbos. If so, can you send me a list of all the parts i would need to finish this turbo off, any suggestions and anything else that would help me out thx again
Old Dec 18, 2005 | 02:43 AM
breakmyfootoff's Avatar
Re: Turbo i recently got
Go to this website. All the info you're looking fore is here.
http://www.junkyardturbos.com/
Old Dec 18, 2005 | 09:41 AM
SMOKNZ's Avatar
The forum looks to be dead.
I helped a guy put together a setup using a Ford powerstroke turbo. He needed to make a few flanges for the oil supply and drain, and the other parts he needed was just tubing and a welder. He used a set of shorty headers and just fabbed piping to the turbo. I made the intercooler for him, and he peiced together the cold side piping and I just welded it for him. Turned out real well, but he has yet to fire it up. You will probably need a wastegate as well, we disabled the internal wastegate and added a tial 38mm one.
Old Dec 18, 2005 | 09:59 AM
on this turbo theirs a built in wastegate, shopuld i not use that??
Old Dec 18, 2005 | 12:41 PM
The built in wastegate will be fine, It's probably set for around 5 psi or so. Some people will disable the internal wastegate and use an aftermarket wastegate but only if the are going to run more boost.
Old Dec 18, 2005 | 06:37 PM
onlyone07's Avatar
If the turbo came off a turbo Cummins motor, it's a Holset HY(or HX)35 series turbo. They work really well with 2.3L Fords(I know i traded a 2.3L turbo Mustang with a holset for my T/A) and STOCK 5.0's. The wastegate has either an 18 or 23 psi spring. I forget which it is.
Old Dec 19, 2005 | 12:00 PM
will this holset hx or he 35 be good enough for my lt1 camaro to do 5-7 psi? and maybe go up further than that later r what other turbo would u recommend ??? i sorta want a big turbo on it but dont wanna spend a **** ton of money of course
Old Dec 19, 2005 | 12:36 PM
whats best way to do a turbo on a 355 forged bottom eng with a cc306 on a 114lsa, some suspension mods, head work, trany work, stall
Old Dec 22, 2005 | 08:35 PM
JZ 97 SS 1500's Avatar
First swap cams, then buy a turbo that is properly sized. Anywhere from a 70mm to 76mm depending on what power you are wanting to achieve.
JZ
brothaslide
Jan 9, 2016 12:11 PM
MichiganSkip
Aug 6, 2015 09:38 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
SergheiS
Jul 5, 2015 03:27 AM
