3bar MAP over 15psi?
Old Jan 28, 2006 | 02:57 AM
ZBLKHELLRZR's Avatar
Just wondering what the consensus is for 15psi and over. Just been searching around and seems most only use a 2bar. I'm shooting for 18-20psi on a 93. Any advice would be greatly appreciated.
Old Jan 28, 2006 | 07:20 AM
engineermike's Avatar
Re: 3bar MAP over 15psi?
I'd say the vast majority uses the factory 1 bar.
Old Jan 28, 2006 | 07:37 AM
rskrause's Avatar
Moderator
I never saw that there would be any reason to switch.
Rich
Old Jan 28, 2006 | 05:06 PM
Well thanks for the heads up guys. I guess I'll leave the search button alone for now.
Old Jan 29, 2006 | 07:20 PM
lethal93ta's Avatar
I have a 2 bar for on mine but I put a DFI system in my car.
Old Jan 30, 2006 | 01:22 AM
SilverSinna's Avatar
I wonder if using the stk ECM vs a stand alone has anything to do w/ switching to 2 or 3bar maps?
Old Jan 30, 2006 | 08:02 AM
NYSS Guy's Avatar
I've got the stock pcm, and use the 2 bar setup. I use HP Tuners 2 bar speed density setup. Works really well, although I'm still in the middle of tuning the new setup.
Old Jan 30, 2006 | 03:57 PM
Pampered-Z's Avatar
I'm running a P600B with 15lb pulleys. Now I know I won't see 15, but I am using a 2 bar map with the stock ECM. Alvin (PCMforless) did my turning so the MAP can determine boost.
I also have an electromotive DFI with an opti eliminator and it says a 2-bar for up to 12 and a 3-bar for 12+
Old Apr 6, 2006 | 10:40 AM
Question Re: 3bar MAP over 15psi?
Bring this back from the dead. Does anyone know if a voltage regulator is required to run a 3 bar map? Or can a stand alone ECU compensate for it? The guys from alky control say you need one and I never heard of this before in all the thread search's I looked up.
Old Apr 6, 2006 | 11:57 AM
rskrause's Avatar
Moderator
The voltage range is still 0-5v.
Rich
Old Apr 7, 2006 | 11:24 AM
BADST95's Avatar
Thumbs up Re: 3bar MAP over 15psi?
You'll need the 3 bar map. A F.A.S.T. sytem will work just fine. You will need to change the factory MAP pigtail harness. The 3 bar MAP sensor is slightly different than the stock MAP. Or you can modify the factory pigtail to work with the 3 bar MAP.
Old Apr 7, 2006 | 12:16 PM
Mitch I got a TTA 3 bar map so I'm good w/ that. Just trying to understand why Alky said what they said. Nevertheless I've got 2 3 bar so if I fry one I've got the other.
Thanks Rich and thank you Mitch for ALL your help Mitch.
Old Apr 7, 2006 | 12:26 PM
BADST95's Avatar
You won't fry it. I have no idea why Alky said what they said.
Old Apr 7, 2006 | 12:49 PM
Julio at Alky means that you need a 5 volt power supply to run his 3 bar map for the alky injection. This one is separate from the one on the intake manifold so it needs power also. The one in the intake gets its 5 volts from the ECM just like all the other sensors.
Old Apr 7, 2006 | 01:06 PM
Ok now I understand. So where do you guys mount the other MAP? Not like I'm doing that but just curious. Thanks again guys.
RUENUF
Mar 13, 2016 03:37 PM
SEOJustin
Sep 24, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Aug 18, 2015 07:08 AM
FredM
Aug 14, 2015 01:49 PM
