choosing injectors, suggestions?
Old Dec 4, 2005 | 10:00 AM
blown94's Avatar
Got an LT1 thats got a 220/230 114lsa, full bolt ons including some LE2 equivalent ported LT1 heads. Going to run a powerdyne, which I already own, at about 6-7 psi with an alky injection kit, no intercooler. What size injectors am I going to need?
Old Dec 4, 2005 | 10:54 AM
SiCk PuPpY's Avatar
Re: choosing injectors, suggestions?
I have a similar set up; Bryan (PCMforLess) recommended 42 lb SVO injectors for my application. You can get 'em new on EBay for about $250 shipped. They are supposedly good to about 600 hp. Here's a link to the calculations page:
https://www.camaroz28.com/calcs/index.shtml
Old Dec 4, 2005 | 07:09 PM
blown94's Avatar
yeah i tried that last time and got an error message. Wasnt sure if it was my fault or what. How do you get V.E.? And since I dont have a dyno chart, how do ya know where your max torque is? Maybe i missed something, ill try again.
Old Dec 6, 2005 | 09:46 PM
EDS Z28's Avatar
I just use the basic well known formula:
Injector size = (HP X BSFC) / (8 X duty cycle)
For a blower car, the BSFC is supposed to be about 0.55 to 0.60.
So, assuming 600 HP, a BSFC of 0.55, and an 80% duty cycle:
Injector size = 51.5 lbs/hr
You can increase the power potential of an injector by increasing the fuel pressure.
You are not supposed to run an injector over 80% duty cycle or it could overheat and fail.
Old Dec 18, 2005 | 01:30 PM
blown94's Avatar
Thanks a lot for that info, looks like 42 lb'rs should work just great and no risk of overworking them. Im assuming I am going to need a better fuel pump to run these though. Is there a pro/con to adding an inline pump to installing a better unit in the tank and tossing the stock'r or what?
Old Dec 19, 2005 | 09:14 PM
97WS6SCharged's Avatar
Yeah, the inline pumps are noisy and they're only good at increasing pressure, not volume.
Old Jan 10, 2006 | 01:39 PM
snorkelface's Avatar
Question Re: choosing injectors, suggestions?
I'm assuming that the HP variable should be based upon flywheel power, correct? Also, would it be better to figure the duty cycle at 75% or so as to be safe?
Old Jan 11, 2006 | 09:51 AM
Yes, flywheel hp. 80% is the safe standard usually.
cobrakilling101
14
Mar 17, 2015 10:42 AM
carl.froehlich
Mar 13, 2015 12:38 AM
grabbem88
Feb 22, 2015 11:16 AM
