NGK iridium plugs are fine for a supercharger right?
Re: NGK iridium plugs are fine for a supercharger right?
Originally Posted by Justin96'WS6
I am putting on my D1SC this weekend, on my LT1 i just put these direct replacement ngk iridium's in last month, or should i go with a tr6?? Thanks
You don't want to run any kind of plug that has a grounding pad spot welded to the ground strap(s). Many of the newer "precious metal" plugs have these pads. They could come off in a supercharged application. One heat range cooler than stock, just your basic resistor plug, should get the job done in a street setup up to 12 pounds or so.
TR6, NGK Iridium, Autolite 103, etc.
My car could care less. They all work, none seem to make a difference. My problem needed programming and DELTEC!!!
Gapped at .030. no improvement, no decrease. Just a lot of headache to change them.
ATI #8PSI, 383 with -31cc JEs.
racecarz28
Mar 30, 2015 09:55 PM
ferraricameron
Jul 29, 2002 07:46 PM
