Forged pistons and Forged rods + 12psi of boost
I have a 94 camaro z28 lt1. I currently have a turbo system on the car. I just wanted to know if I just replaced the stock pistons and rods in my car over to forged would it handle 12psi-15psi of boost. Any information would be helpfull. Also what rwhp range should I be in with 12-15psi of boost with stock heads and above?? I only plan to drive around all the time on 5psi and when I really want to run high boost -- I will turn the switch on. So basically I dont see what's wrong with just replacing the pistons and rods - since I'm not going to be having it on all the time crusing. - Mike
Re: Forged pistons and Forged rods + 12psi of boost
It's a sts t-67 turbo. Basically I just wanted to do a cheap rebuild so I could run higher boost. There's a ton of people making 550rwhp 633rwtq with just forged rods and pistons - stock crank,heads and all. Plus I dont intend to be running high boost all the time. 85% of the time I will be running 5psi - Mike
Originally Posted by onlyone07
I don't see how that would be a problem. As long as the compression was lowered to handle it.
Henson071
Aug 4, 2015 09:32 AM
Catmaigne
Jul 14, 2015 05:17 PM
