powerdyne set up ????????????'s
Old Jan 13, 2006 | 05:25 PM
onetransam4u2nv's Avatar
i have a 95 formula m6 with pacesetter lt's y-pipe no cats borla cat back spec stage 3 clutch and flywheel 4.10 gears i recently bought a powerdyne 6psi supercharger. my ? is im going to add a 52 mm throttle bodie(how about the ones that are cheap on ebay anyone have these with good luck) walbro255 in tank fuel pump and 40 lbs injectors with possible a lt4 hot cam kit and a good tune. whats your opinion on this setup and what type of rwhp and rwtq can i expect from this setup the car only has 56000 on the clock i know the dangers of the blower but i wanna know if this setup will work well together
Old Jan 13, 2006 | 06:24 PM
blown94's Avatar
Re: powerdyne set up ????????????'s
hot cam is not a good choice. its not horrible, but you'll see more gains from a blower grind. try the cc305 on the 114 lsa. Id guess you'll see around 400 rwhp. Also, just go with the 58 MM TB. You can open up the manifold holes yourself with a die grinder. Do a search and you should find the info on how to do it without getting shavings in the manifold.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
z28leno
Mar 12, 2015 07:42 AM
FredM
Mar 6, 2015 03:04 PM
Jan 23, 2015 01:13 PM
