2nd ECU fired!!!! Whats going on??
Old Nov 22, 2005 | 06:08 PM
speedracer69's Avatar
I'm using tuner-cats to do the tuning.
ALDU1 USB-to-ALDL Converter
CABL1 OBD1-Style ALDL Connector
moates stuff
I have fired 2 ECU's because I got a "cable failure" code each time.
The first time I got it, I bought a new ecu and then programed it and everything when fine. I did the same thing both times.
Then I got some different stuff done to the car so i when to change the program again.
And i got the same code "cable failure" and the 2nd ECU is fried.
What is the deal? Is there a problem with the cable?
Old Nov 23, 2005 | 08:40 AM
blitzer454's Avatar
Re: 2nd ECU fired!!!! Whats going on??
Did you try removing power from the ECU after the programming failure? I've experienced a similar problem a couple of times when using TunerCAT, I was able to get the ECU working again by pulling the fuses to the ECU, waiting 10 minutes and plugging them back in.
Old Nov 23, 2005 | 12:28 PM
that does not work. I have the 1st ecu that fired and just pluged it in and nothing
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Ks0209
Oct 1, 2015 07:32 AM
KYWes
Sep 26, 2015 08:49 AM
